I use keyswitches below, wired so that they can lock out the locking toggle switches on the flybridge. I like the toggles, and my upper engine panel is filled with diesel stuff and there would be no room to give an extra pushbutton the correct space around it.
I would recommend
http://sccatalog.honeywe...1-50.series.chart.1.pdf (data sheet) which will do the job nicely.
Looking at the data sheet, you can see that you get the function you want if you connect BATT to 2&5, IGN to 1, START to 4, and ACC to 6. Note that standard mounting is with the momentary end down, you want it to be up.
You can get some from Newark at
http://www.newark.com/ho...oggle-switch/dp/23F1988 for around $25. Remember, these are very good switches, widely used by industry and the military. I use this grade of switch always, they never fail. You can use rubber boots with them for looks, but you don't need them. They can be had with locking levers: you have to pull the lever up to move the toggle. I prefer these, since I don't want rough-housing teenagers accidentally running the starters. I guess if I wait a couple of years, that won't be a problem....
