Thanks: 6 times Was thanked: 7 time(s) in 5 post(s)
The tab's mounting plate is isolated from the hull with an isolator and insulating sleves on the screws. The isolator is mearly a 1/16" piece of vinyl (or plastic?) the same size as the tab mount area. The holes on the insulator match the mounting holes for the tab. Some of the screw's insulation were messed up so they were fixed with 1/4" nylon washers and a 1/4" piece of heat shrink to act as a collar. Got the washers and heat shrink at Lowe's. The insulating vinyl gasket was already there. Surface Interval 1975 28' Express, Single M360 Specs: http://www.boatm8.com/my...amp;page=boats&arr=0
Thanks: 9 times Was thanked: 7 time(s) in 7 post(s)
ya sounds good ill use old fish cleaning plastic thanks HP Chadwick bay Sunset Bay lake Erie NY boat name Sunrise 32' f/b fisherman chry 318 twin blue bastards,28'express singel 318 "It would be a labor of love, if I loved to labor" cpt Brent
