Okay here is a Odd problem. Fresh water pump runs great for the hot water side of all faucets including shower. As soon as you turn the cold water side of faucets on ( regardless of weather or not the hot water is on) the pump starts running erratic and eventually trips the circuit breaker. Like I said only happens when you run the cold side of all faucets. No air bubbles in lines, we cleaned and inspected all the lines even replaced a bad faucet. Water pump is a Par max 4.3 gph. Not sure where to look next.
I don't believe its the pump, brand new and plus it runs fine from the hot water side. I was going to check the switch and or circuit breaker to see if it was bad but i don't believe it is because I would think it would trip no matter what water hot or cold is running.
1978 Aft Cabin
Twin Chrysler 440's
Fox Road Marina
