3 Pages123>
top speed
rv
#1 Posted : Wednesday, May 19, 2010 2:05:23 AM(UTC)
Anyone know what the actual top speed-rpm for a 28 with twin 228?
After installing my new distributors with full tank of water (40 ga)l full tank of fuel(100 gal) 4 people on board and three fish. I got a little over 3300 rpms and 22knots.
I will try again with less people. The boat runs great but I expected more rpms and top speed even though I never go top speed except for this test.
Bob
#2 Posted : Wednesday, May 19, 2010 3:00:32 AM(UTC)
Pardon my ignorance, but what are "228s"?
#3 Posted : Wednesday, May 19, 2010 3:23:50 AM(UTC)
Did you mean 318's or 240(hp) or 225 (hp)? You have wrankled Jeff about 228's (which don't exist) and made me use a word I never heard of (wrankle). All before noon.
Seriously, most of the usual Chrysler 318 engines are looking for rpm's in the range of 4K to 4,400. Speed/rpm will depend on load and the propping. Pls list the prop size.
Doug Doty
#4 Posted : Wednesday, May 19, 2010 4:39:00 AM(UTC)
Doug Doty
I will post even though my boat is different, I am hoping to hear from others with my, or similiar combinations in this thread as well.
I rarely go for a ride that I do not open it up wide open to see what she will do on that given day, it is intresting to see the the variables come into play but from this habit I can tell you my boat is over proped right now with 19x22 4 blades as I only get 3500 to 3700 rpm.
My full fuel and water with 5 adults on board in calm, no current water and clean bottom is giving me 33 mph GPS @ 3600 rpms out of the 330hp 440ci. engines in a 39 sedan. I get 150 rpms and 2 mph extra with 2 people and low fuel.
I think by myself with <20% fuel and no water on board I could see 36 mph GPS right now.
My boat has not had any general tuneup parts in nearly a decade because I recently purchased it and has just come out of 7 years of dry heated storage. I have got fresh fuel now and all the fluids have been changed. I am a motorhead so it is going to go faster in due time. I want 40+ out of her so an ultra slick bottom job and some motor pump up work is in her future plans for this fall and winter.
Doug...
440'S 19x22 wheels, 710 HOURS
rv
#5 Posted : Wednesday, May 19, 2010 8:36:35 AM(UTC)
Sorry Jeff 225 hp 318s. with wax maybe 228.
bob
#6 Posted : Wednesday, May 19, 2010 1:27:42 PM(UTC)
I've seen 33mph on the GPS while going downhill. Wind at the back, surfing down waves.
Usually 32.xx or 31.xx depending on trim and fuel.
Turn around 4,400 - 4,600.
I think props are 16x16.
Bridge sedan with 360's.
-K
#7 Posted : Wednesday, May 19, 2010 2:45:19 PM(UTC)
IF those are the correct props, then your boat is a little slow. It doesn't take much crud on the bottom to slow her down. Is that maybe the case?
Doug Doty
#8 Posted : Wednesday, May 19, 2010 3:01:19 PM(UTC)
Doug Doty
I have seen 6 and 7 mph reductions in speed on my 46 Bertram with diesels and my buddies 38 Chris Craft wood lapstrake Corinthian with 427 fords with dirty bottoms -vs- clean fresh bottoms.
rv
#9 Posted : Wednesday, May 19, 2010 10:39:45 PM(UTC)
Im pretty sure the props are correct . I left the boat in this winter it probably does have some kind of build up. I'll check it out may have to pull it out and pressure wash the bottom.
Bob
#10 Posted : Wednesday, May 19, 2010 10:41:58 PM(UTC)
You (and others with twin engines) might try this little test: At a cruising speed (of say, 2,500 rpms) open ONE throttle all the way and note the rpms achieved, then return to 2,500 rpms. Next, do the other engine the same way and compare. If the two readings are similar, then that's all she'll do. But if one is way lower (several hundred rpms) then you need to look into THAT motor. (This test assumes the tachs are reasonably accurate, which can be checked by the synchronizer and by your ear while cruising.)
Here's the deal, and it's far from obvious: A weak engine will pull down the speed of BOTH engines, though it won't appear that way at the time. The strong engine will make only a few more rpms as it struggles to do more than half of the work.
I run the above test every year to keep track of what's going on down there, and I found a bad plug on one of the motors thanks to it. The motor ran fine at cruising speed, but no doubt it was using more gas because of that plug.
BCassedy
#11 Posted : Wednesday, May 19, 2010 11:06:57 PM(UTC)
Jeff,
Great diagnostic!
I took the boat I'm buying out on Saturday (braved the Ohio in Cincinnati... not too much crud in the water), and we found the port engine lagging behind. Surveyor took her out Monday and came up with the same problem (port stalled on Saturday and Monday multiple times). His feeling is that it's:
1. Fuel filter
2. Need for gas drier (boat's been sitting unused for a lengthy period without substantial engine use,
although the owner advises he topped off the tanks and dumped "large bottles" of stabilizer in each
tank.
3. Carbuerator will need to be rebuilt.
Your test is a great way to get a benchmark reading.
" Sunset Seeker "
1988 32' Fly Bridge
Raw water cooling
Freshwater boat
Dave Morris
#12 Posted : Thursday, May 20, 2010 10:58:04 AM(UTC)
Dave Morris
Though I would not expect to find them in a Big BigM. In the late 70's early 80's Mercruiser called their 305 4 brl "228" so there is such a thing. I had one in my 1978 F25 Trojan .
5.8 Chryslers 275hp each.
vitalidle
#13 Posted : Thursday, May 20, 2010 12:17:56 PM(UTC)
My 28 sportsman with flybridge and twin 225's runs 36mph on the gps at 4000 rpms. Its strange at 2500 rpm's the boat runs 26 mph, at 3200 rpm's it runs 30 mph. I guess Im just not used to twin inboards. Seems to me if it runs 26 mph at 2500 rpm's the boat should run faster then it does at 3200 and wot. Thats with a tad bit less then half a tank of fuel.
Sean Cornish
83 28ft Sportsman twin 318's
Homeport: Munising, MI.
#14 Posted : Thursday, May 20, 2010 1:27:14 PM(UTC)
Ran her up this evening and left it there until the top end leveled out. Both engines bounced around 4060-4080. It takes a few seconds to work up to those numbers. Usually top out at 4040, 4030 or so and then slowly work up and bounce around.
I could only get 31.2 mph.
Full fuel and I did have the bow down to compensate for the fuel load. Boats been sitting at the dock for a month too.
PS. I followed a twin sportsman on trailer down the road this afternoon. I have always wondered how fast those could go. Don't see many twin sportsmans. I like that 36mph. Bet thats a fun ride!
#15 Posted : Thursday, May 20, 2010 11:09:36 PM(UTC)
That's about right for a 32 footer. Mine, with 360s, did about 32 mph before I re-proped it.
rv
#16 Posted : Friday, May 21, 2010 9:54:56 PM(UTC)
Thanks guys I'll try Jeff's suggestion and see if there is another issue with the boat . I'll let you know what I find.
Bob
stan
#17 Posted : Friday, May 21, 2010 11:14:43 PM(UTC)
I ran beside a carver with gps and he said i was doing about 32/33 at 4200, twin 318's 32FBS 1986 MODEL
stan
#18 Posted : Friday, May 21, 2010 11:16:34 PM(UTC)
rOCKIT HAS A 28 WITH TWINS, i WAS ON IT, VERY FAST BUT HE DIDIN'T OPEN IT UP
steveintn
#19 Posted : Friday, May 28, 2010 8:39:16 AM(UTC)
steveintn
i have a 89 28 express. I have only done WOT one time. I don't recall the speed. but at 3,000 rpm i run about 27-28MPH. With two people.
steveintn
1989
28ft Express
w - Twin 318's
#20 Posted : Wednesday, May 18, 2011 12:21:57 PM(UTC)
Let down again Brick wall ONLY 2500 RPMSEh?
Since I've owned my big m...(second season) I've never been able to get full RPMs out of her.
I put new carbs on her a few months ago (had strong fuel smell in cabin..problem solved)...as Collin said, I did check rigging of cables to carb...carb is opening to full limit. Choke is wide open. Let down again...new fuel filters installed.
Put new Pertronix distributors and timed 5 deg btdc, 25 total advance this weekend thinking that was the main reason I couldn't reach full rpms (springs were broken,and everything corroded. Can't believe the engine ran so good with broken springs because at idle it was running at 20 deg advance.
Hit the lake for a test run...can't get more than 2500 rpms d'oh! ...thought well maybe my tachs aren't reading right since I changed the voltage input to them from 9.7v to 13v (not sure how the tachs work), the snap on high tech timing gun I used has rpm reading and it agrees with my tachs...so it's not the tachs. I'm getting a max speed of 19 knots/22mph at a max of 2500 rpms. That's about the correct speed for 2500 rpms I think so my tachs must be correct.
All tuned up! New wires, plugs....everything!
So now what? Only thing left are the propsd'oh! and I don't know what type props I have on her. Had her pulled several months ago and didn't check themBrick wall This is all new to me and I have taken a lot for granted (like the correct props were installed!d'oh! ) I've learned a lot, thanks to you guys. I guess when the water gets warm enough, I'll put on a dive mask and see if I can see any stamps on the props. If I can't see a stamp, I may do an in the water prop removalDancing
I'm getting bummed out because my pockets are only so deep and every time I turn around it's another $1000...and that's doing all the labor myself. I keep telling myself it's better than depreciation on a shiny plastic boatDancing
Questions are:
Do you think my tachs are reading correct with the new coil and distributors?
(not sure about their input, 13v vs 9.7v input on coil, rpm/speed seems correct to me 2500rpms/19kts/22mph. tachs check against Snap ON timing gun reading)
Do you think the same bozo mech that put the fake sheet metal anodes on could have put props that wrong on her? (already know the answer)
With a so so bottom and trim tabs all the way down (to keep nose down), full tank...I should only be giving up 500 rpms at the most...agreed?
[b]I'm thinking the pitch on the props are bad wrong...what do you guys think?
Bummed out and looking for 1500 more rpms!Brick wall
3 Pages123>
This page was generated in 0.402 seconds.
