Not sure what years this part number covers. I have 1985 318s
NAPA starter Solenoid part # ST81SB....$10 (Update....the mounting bolt holes did not line up. One hole was about 1/2 off. I used the part anyway with one bolt holding it. Did not slip around with the bolt tight. Will work but you may want to match the one on your boat by taking it to NAPA.
NAPA carb filter part # napa gold filter # 3044....1985 Marinette 29 Sedan bridge
