The hull wont vaporize overnight. It takes time to cause problems and in most cases years of severe electrical issues to corrode through the hull. Your good with those readings as far as not toasting the hull. You do want to pull the readings in a little.
If the anodes are in question I'd replace all of them. Best thing is to contact John Althouse at
www.marinette.com. Tell him the type of water the boat is in etc and he can provide the proper anodes. There are other sources for anodes too. I'm sure others will chime in.
Also make sure NOTHING is grounded to the hull except right where the negative wires from the batteries are grounded to the hull in the engine room. All ground wires should go back to very specific spots or to bus bars that go back to the aforementioned specific points.
Be sure your shore power cord plugs are clean/corrosion free.
Also check your dock neighbors plugs (a few boats on either side). You may find a bad/melted plug that is putting voltage on the dock ground.
You can also calibrate your CAPAC meter with a digital meter. You should notice a tiny slot screw at the base of the needle. That allows you to adjust the needle. Just parallel a digital meter in DC voltage mode with the CAPAC leads and adjust for the difference.
The change in readings may be a function of utility use. During the day there may be more air conditioners etc running. This may impact the ground on the dock if there is a voltage leak somewhere. Someone has been shore cord or they have something wired in reverse.
Try the search function at the top of the forum. Lots of info.
