High Alternator Temp
collins69s
#1 Posted : Sunday, September 19, 2010 1:28:50 PM(UTC)
collins69s
Hey guys, I finally got around to running a separate ground wire from the neg. pole on the alternator to the neg. post on the battery and after running for a couple minutes, the alt. got real hot.. As in very hot.. Was still charging the battery though.. Disconnected it and all is fine but I wonder what gives? Used 10 or 12 gauge wire.. Anyone?
Thanks,
Sean
SIFF SURF
1972 32' FB Express
#2 Posted : Sunday, September 19, 2010 11:00:07 PM(UTC)
The best way to do this is to connect from the negative pole of the alternator (the one that is actually a stud in the alternator case) to the place where you ground the battery to the engine block. This merely makes sure that the alternator has a good ground to the block, rather than relying on the connection through the mounting hardware.
You do not want to go directly to the battery, because then you have added a wire in parallel with the heavy one that carries the start current, and if that heavy primary ground wire develops a bad connection, the start current will try to go through your alternator ground.
It is possible that the alternator is heating up because it is charging harder. You can check the voltage and see if it is putting out more. But, "charging harder" means putting out more current. This is hard to measure without special stuff. But if it is getting really hot, then it's something else.
I would check to be sure that the new wire is actually going to the alternator case. There are other studs on most alternators, but the ground one has of course no insulation from the case, it just sticks out of it. I would be sure to connect directly to the engine block, preferably where the ground wire from the battery connects, but any good spot will do. I would use 10 awg or even 8 awg wire, since the 10 is only rated for 50 amps or so, in case your wire ends up carrying all the charging current
If you can tell me what kind of alternator and regulator you have, I will look them up and see if there is anything unusual....
collins69s
#3 Posted : Monday, September 20, 2010 3:44:51 AM(UTC)
collins69s
Hey Doug, thanks. It's a Prestolite alternator. I connected the wire to the negative pole on the alt. where there wasn't anything connected before. And it wasn't putting out any more current when connected, actually about 1 v less.
Thanks Sean
SIFF SURF
1972 32' FB Express
#4 Posted : Monday, September 20, 2010 4:54:53 AM(UTC)
As I recall, that stud is NOT a ground but another field terminal which is not used for our application with an external regulator.
The alternator requires no ground... that is obtained through your engine ground etc. The bracket etc. bonds it too the engine block
collins69s
#5 Posted : Monday, September 20, 2010 5:57:52 AM(UTC)
collins69s
There is a pos pole, field pole and neg pole.
SIFF SURF
1972 32' FB Express
This page was generated in 0.098 seconds.
