Thanks for the info guys. A little safety tip on the parallel switch.
Almost got into a bad situation a few days ago because my parallel switch is inop
Pulling out of slip (tight docking) almost made the turn out of slip. Lost port engine, the engine I need to make a turn to stbd
15mph cross wind....
Dead engine because battery was toast ! Couldn't restart ! Fast approaching boats on other side decided starting engine was a lost cause and decided to add throttle on stbd and hopefully get enough speed that rudders would work. Barely made it
The parallel switch is a safety item if in a tight docking situation !
Is this the low watt type that should be used? Not at the boat to check things out, just need to order one based on research.
This looks like the exact thing I need... What do you think?
http://www.amazon.com/Cole-Hersee-24106-Continuous-Solenoid/dp/B001FQL43UINFO
http://www.colehersee.com/pdf/master_cat/e_solenoid.PDF1985 Marinette 29 Sedan bridge
