Can both engines draw virtually all their fuel from one tank when the tank selection valve is set to either/both tanks?
Yesterday, after running the boat (finally!) I filled one tank with about 25 gals, then attempted to fill the second tank. Almost immediately, it overflowed with fuel coming up from the nozzle area and the overflow vent. Nothing, fortunately, inside the boat!
Checking later, I found the tank selection valve was set so either engine could pull fuel from either or both tanks. Normally, the valves are set so the engines pull from their respective tanks. I reset the valves to that position and the engines are drawing fuel OK.
The 25 gal usage would be about right for my season's draw (sorry to say) because the boat has been out only once before for a trial run plus some time running engines and genset at the dock. Both it strikes me as a bit unusual that with the valve set for "either", the draw-down would be mostly from one tank. The only thing that crosses my mind is that one fuel filter could offer a bit more resistance than the other.
If the answer is yes, I wonder what would happen if the favored tank is empty - would the valves have to be reset before the full tank would kick in?
