Jack Marchand wrote:Karl, as a master electrician. I'd say what you did was better than what you had, but.....The wire should stick out 6" out of the box and wire nuts work much better if they are twisted until the wire beyond the nut is twisted, also (this is what the inspectors look for). I find it easiest to use linemans pliers when doing #12 wire or larger wire, as it increases the amount of torque you can apply easily on it. Plus, make sure it has a cover on it when you're done, remember code is all about fire prevention. IT IS YOUR FRIEND! JAM
Jam,
Unfortunately there was not enough slack to give 6" of wire. The only way I could get more wire is to install a 2nd junction box and add some extra wire for the initial box.
I did use my linemans pliers to twist the copper ends before nutting them. I will re-twist the wires to make them twisted beyond the nut. Someone else mentioned wrapping tape around each nut. Is that code or just a recommendation?
I did install a cover which, for some reason cost more than the box. I find that interesting.
It may not be perfect but I think its much safer for me and the house.
