Oil Changer/Pump?
shamrock
#1 Posted : Thursday, January 06, 2011 10:52:06 PM(UTC)
Was thanked: 4 time(s) in 3 post(s)
I am thinking about spring, and the fluid changes. I need help deciding which Oil Changer pump/bucket to purchase? Any recommendations good or bad? Checking reviews on line so far has been inconclusive.
1981 37 Sedan Bridge
Twin 185hp Volvo diesels, Props 19X19 four blade
Twin 150 Galion fuel tanks, Twin 50 Galion water tanks
7.7KW Westerbeke diesel generator
mark klusman
#2 Posted : Thursday, January 06, 2011 11:31:39 PM(UTC)
mark klusman
I've got one that you pump up for the vacume and pulls through the dipstick or where it attaches to the block. Will remove about 5 qts. at a time, but kind of messy and not real impressed with it. I believe they make some that pump with a motor . Theres a venders list here on the fourm that can probably help. I'm sure you will get plenty of help from the members. Check the Dock Store at the marina ; and see if they got one. Like most marinas around here they will use West Marine.
Your right Karl, i stand corrected on the pan. Mark
Knot Normal
28FT. Express
Twin 318's
Ten Mile Tn.
#3 Posted : Friday, January 07, 2011 12:21:58 AM(UTC)
I’ve made this up for a oil drain system it lets one drain all 6qt. just hook up any oil drain pump & U get it all out.
Big BigMs Live On Dancing
http://s25.photobucket.c...mp;current=Pic294-1.jpg
http://s25.photobucket.c...amp;current=Pic291-1.jpg
#4 Posted : Friday, January 07, 2011 1:22:54 AM(UTC)
That's a slick setup, Norm, but will only work for 1987 and later.
I've seen 1987 Marinettes with both styles of Chrysler's.
The earlier dip tubes go into the the block at the top, unfortunately.
On mine I have to remove the tube and take trim tab hose and weasel it in, down and around the bottom of the pan. Its a pain and almost never get it all out.
I use a little impeller pump mounted on a bucket. The pump works well but the rubber impeller does not hold up. I suppose the dirty oil destroys it over time.
Search Google for oil change pumps and oil change pump reviews.
#5 Posted : Friday, January 07, 2011 1:52:30 AM(UTC)
Here is the one I have used for the past 6 years. No hassle and works well. I use it on my boats and other small engines etc.
The 6.9 qt model is the one I use. It actually does not hold 6.9 qts holds about 3/4 of a qt less. I remove the dipstick tube and then I can get the small hose all the way to rear of pan.
http://www.westmarine.co...0434&classNum=10440
Here is another source Wholesale Marine. I have used these folks for bottom paint and have had excellent service from them.
I notice they now offer a larger model over 14 qts.
http://boats.wholesalema...;Dk=0&N=0&Nty=1
P.S. It is virtually mess free. My big pail with Jabsco pump on it is a pain in the.
#6 Posted : Friday, January 07, 2011 5:13:38 AM(UTC)
I made up a rig using one of those old, now illegal propane tanks (which you can get for free). A few pipe fittings and two hoses and away I go, using one engine as my vacuum pump as it sucks the oil out of the other one. I then switch engines and do the other one. Works slick and, since the drain oil is inside the tank, there's no mess.
Got more info if you want to build one.
#7 Posted : Friday, January 07, 2011 5:24:09 AM(UTC)
Been using the Big Boy Topside vacuum rig with a thin tube that goes into the dipstick. DOn't know how the other units operate, but to create the vacuum one must pull the pump handle up which is tougher than pushing down on the handle (if there is a model that does that). It gets out 4 of the 6 qts but I would imagine that figure would increase if the tube penetrated further into the oil pan. $69 at West Marine.
jralbert attached the following image(s):
jralbert attached the following image(s): 11935_T[1].jpg
shamrock
#8 Posted : Friday, January 07, 2011 6:25:51 AM(UTC)
I just ordered the Jabsco. , besides efficient extraction it has revers cycle to make it easier to unload the bucket. Just flip the switch and let the oil pump out. The link appears to be the best price.
http://www.boemarine.com...cts/17...-gallon-bucket
Thanks to all for the help.
bpboater
#9 Posted : Friday, January 07, 2011 7:23:22 AM(UTC)
I have uesed the Jabsco pumps for many years. A word of caution. Use metal hose clamps on all the exit connections. The pumps develop about 20 psi pressure. If the hose slips apart while emptying, it makes a mess. Oil shoots everywhere in small droplets. Don't ask how I know this.
This page was generated in 0.113 seconds.
