While we whittle away the winter with various projects I figured I'd post a non marine carb question.
I inherited a low hours, ~25 year old Airens snow blower with 5HP Tecumseh (I know, its a rod thrower engine) that is leaking gas from a needle valve under what I believe is the carb bowl.
If I turn the valve tight (it still leaks) the engine wont start, loosen a little and it runs and if I gently turn it out more the rpm kicks up and the idle levels out, it then sounds good/normal. The problem is now under a load the exhaust is shooting sparks and flames at random ( too rich?). Also had a backfire. The machine was able to clear the drive with no problem but I need to find some type of gasket material for that needle valve and figure out how to adjust that carb.
I'm assuming there is another needle or 2 on the carb somewhere but I have not yet taken the shroud off the machine.
Short of buying a real engine does anyone have an tips, ideas, troubleshooting procedures?
Thanks,
Karl
