Sanding or Striping
RCPRATHER
#1 Posted : Monday, January 31, 2011 5:44:54 AM(UTC)
Hello all,
I am starting to get my ducks in a row for my big upcoming spring painting project and needing some good sound advice which I can always count on you guy's. I talked to my local marine parts store about my paint issues "checking" and their advice was to go ahead and strip the old paint off. They said to go to my local auto parts store and purchase a product called Aircraft paint stripping? He said you roll it on let sit for a period of time and take a puddy knife and remove the bubbled up paint. Just a side note I am painting the flat surfaces above water line. Or should I sand with 220 grit? I will be posting pictures tonight so you can get a better idea of what my current paint looks like.
Thanks,
Rob
"Great Escape"
32ft 1972 Express
Twin 318's
Located at LBYC
collins69s
#2 Posted : Monday, January 31, 2011 5:52:27 AM(UTC)
collins69s
That advise sounds a bit suspect.. Lots of info about painting on several threads here.. I try to avoid stripping paint. But these other guys know way more about it than me..
Sean
SIFF SURF
1972 32' FB Express
#3 Posted : Monday, January 31, 2011 10:03:48 AM(UTC)
Stripping didn't work for me. I tried it on a small area. Somebody recommended some miracle remover. It melted and bubbled the paint alright. But you have to be there to scrape it at the optimum time and work fast because it just hardens right back on. It was a mess and I still had to sand.
I have two boats and two different paint problems. One has several coats of who knows what and the other has the original factory paint. I took the most conservative approach with the boat with factory paint. First I sent my paint, the flybridge and the side cowls out to professional auto painters. These pieces have the trim stripes. They did a great job. Then I sanded the decks and cabin sides starting with 80 and ended with 120/150. I had a lot of spiderweb like checking and a lot of "pinholes". I tried to sand past the rotten paint keeping the brown undercoat wherever possible. You have a lot of filler under that paint. Where it was sound I left it. Where It broke out I filled it with an epoxy compound. In some spots I sanded all the rotten paint off and still had pinholes and cracks. Here I used a polyester finishing putty, Evercoat Easy Sand. It worked great. Dries in 20 minutes and has built in etchant. Unfortunately I have to sand and reapply the topcoat because I left it out without cover over the winter. That was just like putting it underwater (DUH!) and the paint bubbled up on the horizontal surfaces.
The boat with multiple coats will require more horse power. I got a UNI-RAM sandblaster on EBAY. It has a vacum that recycles the media and you don't need a moonsuit to run it. I don't have a compressor which will drive it so I will have to buy or rent one. Any compressor which will run the blaster will also run air sanders. This boat could also use a bottom job. I only needed electric sanders for the boat with the factory paint.
#4 Posted : Tuesday, February 01, 2011 1:23:00 AM(UTC)
I am one of the world's worst painters and some guys on this forum could do show boats, but for what it's worth: I could see no reason to remove paint that sticks, and the factory did a fine job. I sand what's there with 36 grit (!) to get a clean, rough surface, then roll on epoxy sand-able primer. I then sand the primer with 80, 160, and 220 to get a smooth surface. Then roll on the topcoats. I know there will be a storm of entries saying that I'm nuts, and I can't argue but it works for me and looks OK.
#5 Posted : Tuesday, February 01, 2011 4:26:47 AM(UTC)
And a reminder, that any place where you cut thru top bare metal has to be properly ethed and primed before overcoating. And, another reminder that bare aluminum must be treated (coated) with hours of being bared. Not days, not overnight -- 4-6 hours -- or the paint won't stick. One coat will then allow you all the time you need to go to the next step.
BCassedy
#6 Posted : Tuesday, February 01, 2011 7:41:08 AM(UTC)
Joel (or ???)
Will bare aluminum need to be etched when using the following 2 part epoxy (water immersible) to fill pitting within the alloted time frame?
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100649630&N=10000003+90401+502487
" Sunset Seeker "
1988 32' Fly Bridge
Raw water cooling
Freshwater boat
#7 Posted : Tuesday, February 01, 2011 1:31:30 PM(UTC)
You can get epoxy to stick to bare aluminum if you put some on a piece of sandpaper, and wet sand it into the surface. You sand off the oxide and coat it before it can oxidize again. Works great with WEST epoxy, don't know about others.
I have done the same but used a stainless wire brush instead of sandpaper. That works too. Otherwise, I would etch it even for epoxy: the problem is that the oxide layer that forms comes right off, and your epoxy with it. If you drag your finger across a piece of bare aluminum, you get a black mark on your skin. That is oxide.
#8 Posted : Wednesday, February 02, 2011 12:37:20 AM(UTC)
Agreed. You'd be surprised how quickly that oxide films grows on a freshly sanded aluminum surface (as illustrated by the clear epoxy turning grey as you sand it in). You almost can't do this before the oxide film is there!
This page was generated in 0.167 seconds.
