In your engine, of course. This subject comes up from time to time and, when asked, I always give the usual, generally accepted answer: you need at least 10 psi per 1,000 rpms. Uh-huh.
Well! I was watching NASCAR qualifying for Daytona and they said that, while qualifying, the team engineers lower the oil pressure to reduce pumping loads on the engine--anything for a bit more speed. Now, understand that the SAME engine MUST be used in the race or you get hit with a major penalty--like loosing a dozen spot on the grid. So, there's no way the teams will risk puking a motor just to qualify a bit higher on the grid.
Okay, so what oil pressure do they run? Well, first of all these restrictor plate motors are now turning over 9,000 rpms--and that's ALL the way around the 2 1/2 mile track! Furthermore--again to reduce friction--the motors are deliberately run hot--about 260 degrees--with the oil preheated to at least 180 degrees. So how much oil pressure do they run? Would you believe--hold on to your keyboards--about 30 psi!
Think about that when you're out cruising this summer at 3,000 rpms with "only" 40 pounds oil pressure.
