Just swapped over to "one wire" alternators yesterday (not by choice). I also used the hot wire going to the voltage regulator on Jeff's advice. You will need to make your own wire because the carb does not come with wire.
You will need about 3 feet of wire per engine, 2 ft for hot wire and about 7 inches for ground wire to carb base.
The hot wire to voltage regulator has a female spade connector, so you will need to make a male end spade for the connection. The carb choke also has a spade connector...can't remember if male or female.
Still haven't tested my elec choke yet, because my motors are still winterized
10 more days before dewinterization
