Groups: Admin, Administration Joined: 12/4/2007(UTC) Posts: 1,871 Points: 4,247
Thanks: 2 times Was thanked: 28 time(s) in 28 post(s)
Here a part of what Pettit Eco A/F paint recommends to apply their product over P P S to read all google Pettit Eco it’s extremely long
Mix paint thoroughly to ensure toxicants are evenly dispersed throughout the can. All surfaces must be clean, dry and properly prepared prior to painting. Previously Painted Surfaces: If the previous coating is in good condition, thoroughly sand with 80 grit paper then solvent clean with 120 Brushing Thinner to remove residue. Apply two finish coats of Ultima Eco. If the previous coating is soft or in poor condition, remove to the bare surface by sanding or using a paint & varnish remover. Proceed with appropriate bare system as described below. Old tin copolymers must be removed or sealed with 6627 Tie-Coat Primer before applying Ultima Eco. When sanding old bottom paint, always wet sand and take precautions against getting the material in your eyes, nostrils, open cuts, etc.
Bare Aluminum: Sandblast to clean, bright metal and remove blasting residue with clean, dry compressed air or a clean brush. Immediately apply three coats of Pettit 4400/4401 Aluma Protect Epoxy Primer followed by two finish coats of this product. Read and follow carefully the instructions on the Pettit 4400/4401 Aluma Protect Epoxy Primer label. If the surface to be painted is smooth aluminum, apply one coat of 6455/044 Metal Primer and allow to dry for 2 hours, then apply two finish coats of this product. Read and follow carefully the instructions for application and top-coating on the 6455/044 primer label.
Big s Live On As well as Stryker's http://www.picturetrail.com/gid23690601 Try it now there's music to listen to while U view the Big M's
http://www.PictureTrail.com/club/club/index.php?clubID=20726 this one for the Pix club
