I assume you are checking isolation with a digital OHM meter.
These meters are exteremely sensitive and will NOT real OL (unlimited resitance) There is always very small current flow through water to the hull.
Here is what you can do to confirm you are good.
1. Use only the beep function or continuity checker. If it beeps there is too much continuity.
2. If your CAPAC is working use the following recommended Big M test.
Have helper push button on CAPAC while you take a jumper wire and ground Shaft to Hull. If meter deflects downward this is an indication of inadequate isolation.
Even with fresh anodes my boat always reads on the low side in fresh water. I use a mag guppy over the side while in the slip and it keeps the numbers in the proper range and no corrosion observed over the past 6 years in the water.
