Semens is still making the orig. CAPAC unit. Also Zincs.com also offers a portable monitor.
The fact is does not have a monitor installed is NOT the cause of the corrosion.
One must investigate: Isolation, Anodes, Etc.
The Capac unit only is a monitor.
They did build an Impressed Corrosion CAPAC system that was/is suppose to be adjustable to help control galvanic corrosion. Most were disconnected due to over or underprotection concerns. Roamer Yachts used them for years and many caused more problems than they solved.
There are other companies that now build more sophisticated Impressed systems a google search will find most of them.
Best of Luck,
