Needing info on spring replacement for original 318 electronic distributors. I can't seem to find anyone that sells them locally at the parts stores....
I'm thinking the mechanical advance is not working properly because when running slowly up to 2000 or so rpm, the port engine starts acting up and backfiring through the carb (edelbrock). Pulled the distributor and found the rusty springs. Also thought about the "can" fuel filters...ordered new ones from Hurricanes and the new one for the port engine is leaking...still working that one.
Thought about the angle of the engines also when underway however the angle should be correct as the both engines have the original intakes with proper angle. Shouldn't be starving for gas based on this.
Anyway, if anyone has any leads on replacement springs for the original distributors would be greatly appreciated.
Also any thought on adding fuel/water seperator kits - would one suffice or should I use two, one for each engine?
Thanks in advance.
1981 32 FB Sedan with 318's and edelbrock carbs.
Keeling Time
1981 32' Marinette Sedan FB
Fresh Water
Twin 318's
Pertronix distributors
Edelbrock 1409's
