prop shaft question
Neal Weatherman
#1 Posted : Tuesday, May 10, 2011 12:15:36 PM(UTC)
My 1" prop shaft shaft flange is drilled for 4 setscrews and lock nuts, only 2 of which are opposed. Should I use only those 2 for balance purposes?
many thanks,
Neal
1965 26' Convertable, single screw, new 230 Hp Mercruiser w/ closed loop cooling, installed 1995, all systems upgraded 2004 to present.
#2 Posted : Tuesday, May 10, 2011 12:26:11 PM(UTC)
Yes
Reminder: Use seizing wire between the two set screws.
Neal Weatherman
#3 Posted : Tuesday, May 10, 2011 1:19:35 PM(UTC)
Dave: This setup has jamb nuts but the screws are not drilled for wire. can I use Nylock nuts or should I drill the set screws to acomodate wire? I appreciate your info.
Neal
#4 Posted : Tuesday, May 10, 2011 1:56:56 PM(UTC)
Jam nuts are fine they have obviously done their job for over 45 years!
I would suggest you check them after you have run a few hrs to make sure they are set.
The more common problem is getting a darn flange off a shaft!
Many are converted to split flanges after a battle and often cutting a shaft and replacing. A real pain!
Jack Marchand
#5 Posted : Tuesday, May 10, 2011 2:13:17 PM(UTC)
Jack Marchand
I agree with Bdave, remove the set screw completely so as not to drag the screws across the shaft.....voice of experience.... and I would recomend wiring too. This is how my boat came. JAM
This page was generated in 0.093 seconds.
