Choke disabled and butterfly wide open.
accel pump in carb verified working...sprays fuel in on advance..
New Edelbrocks...stbd running fine...port as follows
Engine starts ok but I must jocky the throttle to keep the engine running.
After short warm up the engine will idle fine.
Under a load, stalls when throttle advanced...intermittent of course.
FastJeff said something about drilling out idle holes??? That only make sense on the idle problem...what about the stall on accel?
Leak around base cause this?
Weak fuel pump?
Fuel filter? Changed a few months ago, but I guess it could be full of junk causing this.
Plan of action
1. Change fuel filter
2. Change fuel pump or at least swap
3. Swap out carbs to see if it follows
Feel uneasy with a finicky engine when docking
What do you guys think? Anything I missed?
