[quote=verboatn;23979]I have been updating and trying to get running my new (to me) 1977 express's pressure water system. I put in a new Jabsco accumulator tank and a new city water input with pressure regulator. I updated the hoses in the closet where the pump is. The pump works and generates pressure. My problem is when I turn on the tap, pressure is fine, 5 seconds later it slows to a trickle. When I hook up city water and pressurize, the same thing happens.
Does anybody have any ideas what could be causing this?[/quote
If your taps are original they have a screen under the stems. simply remove the handles and take out the stem cartridge. Make sure the water pump is shut off when you do this. You should do one at a time. with one stem removed turn the pump back on and the water pressure will blow the screen out. Make sure you have a towel readyto catch the screen and water.
"ALUMINATION"
Grosse MI - FYC
