I dealt with this problem years ago and learned that the funky smell and gunk was actually organic material decaying in the tank and falling out of suspension. The marina water supply was not chlorinated then and lots of "natural" algae and critters came along with our water. The chlorine I added to the tank killed them off inside the tank and they decayed and collected at the bottom of the tank. Here are my suggestions:
1. Kill the buggers and filter them before they get into the tank, or
2. Don't add any chlorine but flush thoroughly before and after you use the boat and empty the tank when away, or
3. Move to a marina (like mine) with chlorinated and filtered water supply.
p.s. When I first get to the boat I put the hose in the fill and open all faucets and the shower hose. I let it run several minutes until I smell a faint chlorine scent at each tap. When I leave the boat I drain the tank to prevent the water from getting stagnant while I'm away.
