Afternoon, folks...
Update (multiple subjects, but they were part of this thread, so here goes...)
With the boat still out of the water:
1. Prop changeout - Starboard was "fall off the bone" easy. Once I took the cotter pin out, unscrewed the castle retaining nut, the prop pretty much slid off the shaft. Not wanting to complain, I changed that side out, tightened up the nut, new SS cotter pin and on to the Port side. Now there it was a bit more challenging. I'd purchased a 6" 3 jaw gear puller and was able to get it attached with the rudder turned full to one side**. Replaced the old prop and buttoned everything up.
** Note - if you want to / need to have the gear puller fit correctly, you could, either with a hacksaw or a cut off
wheel, lop the shaft down to about 3". Grind a square (about 1/2" long) at the newly cut off end. This
should allow for a crescent wrench to be used on the now easily squared to the prop shaft.
2. Anodes - attached the prescribed amount to the trim tabs, rudders. keel. ***
3. CAPAC sensor - as mentioned earlier, I found a small hole in the sensor. A check with a vendor resulted in knowing
no such hole should be there. Gobbed on some aquarium silicone (just enough to cover the hole to
keep out water). Sensor clean.
*** After boat's been in the water...
CAPAC reading at 6.4 . Realize that's not good. Think the doubling of the amount of anode used previously
may have masked a problem.
Believe that the cause may be that the bolts in the tranny / prop shaft aren't isolated and there's direct metal
to metal contact. Will be using 10mm bolts with shrink tubing over them (standard 7/16" bolts w/ shrink tubing
wouldn't fit.). Once all are done, will test.
" Sunset Seeker "
1988 32' Fly Bridge
Raw water cooling
Freshwater boat
