Got me thinking. Not sure where the ground comes from to the coil....think the coil is grounded through the distributor housing...must find diagram on this site to check it out.
My limited 2500 rpm problem (new pertronix distributors) could be at the ground on the coil.. I took all the old chrysler electronics out of the loop(ecu, resistor). Pertronix said it sounded like a ground problem..that may be were my problem comes in. Boy I just keep on yakking on this subject on many threads
sorry guys..I won't say another word until I find the solution. Sorry if I hijacked
