Now I need to take the time to redo my fuel line from the fuel pump to carb. I don't feel good about how I have it now. I cut the original copper tube and spliced in flex marine fuel line with two clamps on each end. I don't feel real fuzzy about that modification because I feel like without the barb on the original copper tube I will spring a leak...a fuel leak is not what you want on a boat!
Not to mention this is not an approve marine modification as pointed out by some on this site.
I can't find a good solution yet. I like the Russell Performance set ups
http://www.russellperformance.com/mc/hose/main.shtml They are not marine approved as far as I can tell. They are NHRA (racing approved)and I would feel safe with them installed.
Just a barbed fitting on the fuel pump would work if anyone has a size and source
Any ideas and links would be helpful if anyone has a legal, safe modification on the fuel line.
I think this has been a topic before...but we need links, sizes and part #s.
