Throttles
keeling time
#1 Posted : Sunday, June 26, 2011 9:50:43 PM(UTC)
Need help with throttle advance problem.
I am only able to advance both throttles all the way forward and only achieve 3000 rpm. It's as if the starboard throttle has reached its full travel and will not go forward any further. The port throttle will advance just a bit more but not much.
Both engines are smooth and wanting more but I can't go any further with the throttles.
Any and all assistance would be greatly appreciated.
Keeling Time
1981 32' Marinette Sedan FB
Fresh Water
Twin 318's
Pertronix distributors
Edelbrock 1409's
rv
#2 Posted : Monday, June 27, 2011 5:46:27 AM(UTC)
Look at the linkage at the carbs you can see if the cables are at there limit, if not re adjust them. Check timing advance. Last season I couldn't get more than 2500 rpms
out of the boat. Turned out to be to many barnacles after cleaning and repainting, the rpms and top speed went way up.
Bob
1 user thanked rv for this useful post.
keeling time on 6/28/2011(UTC)
#3 Posted : Tuesday, June 28, 2011 7:19:26 AM(UTC)
Pain it the *ss ain't they! Being anal, I modified the throttles to allow more travel, which eliminated this nonsense.
Realistically, you don't need 100 % full throttle--mine planes effortessly at half throttle (and it's deliberately over-propped. I'll bet yours does too.) The important (to me) thing is that the carbs close, and that the handles are together (twins) at cruise speed. If not, that drives me nuts!
1 user thanked fastjeff for this useful post.
#4 Posted : Wednesday, July 06, 2011 6:55:42 PM(UTC)
Keeling and I just swapped old carbs for the 1409s...we are both having rpms issues. My max is 2500. I am getting max travel on carb.., bottom semi good, new distributors, timed good, most cyl comp cks good (could'nt get tester on 3 or 5, but plugs look ok)....still looking?
Jeff you have the 1409s correct? What is your max rpms with over props?
#5 Posted : Saturday, July 09, 2011 5:50:16 AM(UTC)
The way I'm propped, I get about 3,900 rpms max (3,000 per engine during the Fastjeff Dyno Test).
You're going to have to go through the entire checkout procedure to see where the power is being lost:
1. Use an advancing timing light (borrow from Autozone) to see how much spark advance you're getting. Look for at least 26 degrees total at 3,000 rpms or less.
2. Warm 'em up, idle 'em at 1,200 rpms and--using insulated pliers and gloves--pull then replace each wire on the distributor cap. Note the rpm changes and any cylinder that does nt respond correctly.
3. Do a Fastjeff Dyno Test to seee how the motors compare: At cruising speed (at, say, 2,500 rpms) synch the motors close as possible, then open the throttle on one and note the max rpm. Return it to synch speed, then open the other throttle. If one is dramatically slower, jump on it.
PS: I have Edelbrock 1409s and swear by them.
This page was generated in 0.125 seconds.
