Could one actually get the distributor "one tooth off", or out of alignment worse?
I researched a bit and found that this is "I think", a false statement. As long as your #1 spark plug is firing at the degrees BTDC you set it, how could the teeth on the distributor be misaligned? I even had a tech at Pertronix (brand of distributor I installed) tell me this.
...I think he is grasping at straws!
I think it to be hog wash...what do you guys say?
