Jack,
A couple of considerations from the past when I had seats redone:
- Use exterior grade plywood.
--> You may wish to soak the wood in Thompson's Water Seal which makes it virtually
imperveous to water.
** Cut your drain holes first. End grains and hole grains'll soak up the sealer
like a sponge (good thing).
- Use marine grade naugahyde which will keep down/prevent mildew from occuring.
(Joel's comments about water seepage is dead on. You can't keep water out so using
marine grade works well.)
--> I've found upholstery shops will carry this type of thing locally in Cincy, so
you may find it easily as well.
--> Naugahyde will she a lot of water where any fabric (non stickin' to skin) won't.
It's a trade off. A towel or terry cloth cover will give you the benefit of
not stickin', ease of cleaning, and water shedding.
" Sunset Seeker "
1988 32' Fly Bridge
Raw water cooling
Freshwater boat
