Originally Posted by: goby
LOOKING FOR BENNETT SINGLE(JOYSTICK) CONTROL SWITCH.
THANKS - GOBY
GOBY; I take it that you know that they don't make them any more. If yours is broken at the bottom where mine did there was a small screw that went to the stick. If so you can remove the small screw and cut a same size one but longer and thread it into the bottom then screw the stick back on. worked for me and haven't had a problem yet. If wasted, than the EURO switch by Bennett is the replacement. About $70.00. Hope this helps.
Mark
Knot Normal
28FT. Express
Twin 318's
Ten Mile Tn.
