Tried the Rustoleum
jhemp3
#1 Posted : Wednesday, August 17, 2011 4:03:02 PM(UTC)
jhemp3
I painted the top of the bow seat this weekend. The paint had loosened under the pads and I figured the area would be a good place to try the RO. I sanded with 180/220, cleaned well and painted.with a soft brush. Rolling/tipping would be better but I wasn't as prepared as I should have been. From my level of painting experience, poor, the job went really well and I'm very pleased. The top coat might have been easier to smooth if I had thinned it slightly. Some of you real painters could make it look professional. The Oyster White matches our Marinette off white closely. Don't know how it will hold up but It might be worth a try if you are considering DIY paint job or touch-up.
Jim Hemphill
Detour
BCassedy
#2 Posted : Wednesday, August 17, 2011 8:16:50 PM(UTC)
Jim,
Ummmm... thanks for being the tester/guinea pig on this.Whistle I had 2 dinner plate patches of paint lift off the bow seat this spring (think the tarp filled with water creating a "bath tub" and sat down on the seat for an extended period. The cold water and moist air underneath the tarp left a lot of moisture on the seat and "viola" dinner plate for 2...) I've needed to paint those spots so your report is greatly helpful!
Thanks,
" Sunset Seeker "
1988 32' Fly Bridge
Raw water cooling
Freshwater boat
jhemp3
#3 Posted : Thursday, August 18, 2011 7:36:32 AM(UTC)
jhemp3
Bill, I found two construction welds when sanding. I think they could increase the failure rate of the original paint. Yes, they result in two "pie plate" or larger loose spots in the paint.
Jim Hemphill
Detour
jimski2
#4 Posted : Saturday, August 20, 2011 7:00:17 AM(UTC)
I coated my old mobile home with Rustoleum sprayed on with an electric Wagner spray gun. The paint job was fine, long lasting, nice and white. The problem is that the fish oil based paint is conducive to mold growth and regular washing with a power washer was needed. I now painted it with a water based paint that has a biocide to stop the mold from appearing.
#5 Posted : Tuesday, August 23, 2011 8:45:03 AM(UTC)
Thanks for the info. I posted that I was going to try the rust-oleum marine products but for various reasons went with Briteside at four times the cost. The biggest reason was a closer color match to existing painted areas. When I finish the 32' project I still have to put paint on a 28' sedan. I may try the rust-oleum for that. I have the marine etching primer and topside paint. It will all depend on how well it rolls and tips compared to Briteside. We are spot painting bare aluminum with the etching primer. Be clear that we are talking about the rust-oleum marine paints - not the old rusty metal fish oil paint.
keeling time
#6 Posted : Tuesday, August 23, 2011 9:56:00 AM(UTC)
I've read your posts regarding the marine Rustoleum paint and etching primer and have decided to try it myself in a few weeks. I'm going to start in the upper helm area and work down from there. Hopefully it will be a little cooler - it's been in the mid 90's for a few weeks here, way too hot for this project. I'm sure it will be time consuming but, it's good therapy. I'll let those that are interested know how it goes.
Keeling Time
1981 32' Marinette Sedan FB
Fresh Water
Twin 318's
Pertronix distributors
Edelbrock 1409's
jhemp3
#7 Posted : Thursday, August 25, 2011 7:36:57 AM(UTC)
jhemp3
Yes, Yoop, the paint I used was the marine type.
Jim Hemphill
Detour
#8 Posted : Thursday, August 25, 2011 9:28:05 AM(UTC)
Today is the day for the final coat of Briteside on the cabin. Painting outside on land is very difficult. This week a gravel truck started unloading nearby and a kind of slow maintenance man spray my boat and car with gravel from his lawn mower. I also had rain hit some work right after we painted. That work was to be coated with non-skid so the craters in the paint blended right in. I need some luck to finish in good order. My helper and myself are painting rookies and it shows. Here are some tips. Thin the paint correctly. The paint must start laying down immediately. If rolling only you must see any bubbles starting to pop out within seconds. But over do it and the paint will run. We used the white foam rollers 4" (mostly) and 6" for curves and sides. We used a 9” mo-hair 1/4" nap roller for the roof decks which we just rolled but the foam would have worked. Roll off the edge of the big rollers in the pan or the edge will show up in the work. My helper had trouble avoiding painting with the tipping brush. He will be limited to rolling for the final coat. We had to sand to much of his work off the boat when he handled both the paint, roller and tipping brush. The Interlux rep told me rolling only will yield a job that looks good from 10’ and tipping would reduce that to 5’. That is a little pessimistic. If we can get it right we will have better than a 5’ paint job.
#9 Posted : Friday, August 26, 2011 8:41:24 AM(UTC)
Well the cabin area painting went well. The owner of the yard blocked out 4 hours and took over the final coat. My rookie helper was to roll and he was to tip. I was relegated to preping and taping the cockpit area so I didn't see the whole thing but it would have made a great video. First he thinned the paint more that we did on the first coat. We were afraid of runs. He wanted time to do over any part he didn't like. His instructions to the helper were calm and constant. Many times he had him do an area over and work the roller both ways. He made adjustments on the fly and if he didn't like the result they did it over. Our sticky mix on the first coat didn't allow this and as a result we had to sand a lot of mistakes off. On the big roof area in front of the windshield we were only going to roll it with a long handled brush because we didn't want to climb on the area to be painted. He just climbed up on the deck in his stocking feet. He rolled and tipped the curve under the windshield himself. Then he blocked the area off into about six rough squares. The helper rolled one square ahead of him as he tipped off each section in turn. Who knew this was allowed? They did the cabin sides at the same time. Lesson - if the deck is clean and your clothes are clean you can climb on a deck to paint it. There is an art to it all. He showed the helper row to roll without slopping paint over an edge. I wish he showed him for the first coat. The results are good and I am keeping them - no wet sanding or buffing is planned, If we did a better job on the first coat the results would have been better. I stayed with high gloss and this brings out waves and imperfections in the hull anyway. My previously painted flybridge and side cowls are more of a satin finish slightly off in shade. I don't care. I want to get in the water and I know enough now to change stuff later. Go for it Jim.
jhemp3
#10 Posted : Friday, August 26, 2011 12:46:15 PM(UTC)
jhemp3
Thanks for the the good posts and encouragement. I think not having done it before is the biggest impediment to my proceeding. I agree, thinning is an important aspect of producing a quality finish and would have made a positive difference in my test.
Thanks again,
Jim Hemphill
Detour
jhemp3
#11 Posted : Monday, October 03, 2011 6:51:47 AM(UTC)
jhemp3
I visited Detour for the first time since the reported painting experience. It's been six weeks or so and I'm happy to report that spider poo was easily removed and I continue to be impressed, if I say so myself, with the Rustolium. The biggest surprise is how closely the Oyster White matches my Marinette white. I believe spot painting will be very acceptable. Again, roll and tip and a 10% thinning (as directed) would give a more satisfactory surface. This was a great weekend to anchor out and enjoy.
Jim Hemphill
Detour
This page was generated in 0.148 seconds.
