Here we go again
Be sure to get barbed fittings at carb and pump. Let us know where you find them as I need some myself.
There are a few older threads on the board on this subject. Many people say the metal fuel line has been there for over 30 years with no problems. Some say they get cracks...
. If you aren't having problems why mess with it? Most change over so they don't have to pay an arm and a leg for a fuel filter that fits the rigid lines. Some may have found a cheap source for fuel filters...I never could so I went flex fuel line so now I have many choices of filters to choose from. The cost to do the conversion will be about $60 and about a hours work.
I converted mine by cutting the rigid fuel line and sliding the rubber fuel hose over the rigid tube and using two band clamps (with no barbs)...this is a mistake that I must correct before I have a leak/explosion
