Don't forget to put some goop on the screw threads before you reinstall everything.
If the hardware has not been removed since the factory you should have noticed a little bit of caulk on the end of the screw threads.
I can only guess that bit of goop helps seal the screw hole, preventing water from getting between the paint and Aluminum at that very tiny area.
I failed to do that after repainting and have a couple bow flanges that are slightly bubbling.
The flanges also need to drain.
The weep holes on the flanges are worthless. I clamped 2 bottoms together and ran the drill press through the existing weep holes to make them bigger. That worked ok but the gasket material gets pressed up into the holes and they will eventually plug.
I ended up using nylon washers in place of the gasket material. Works great, cant really tell unless you look hard and I can use the hose to rinse the mud out from under the entire flange.
They have been under there for 2 - 3yrs. Still tight as monkeys fist.
