2 Pages<12
Deck hardware removal and paint job
#26 Posted : Tuesday, April 01, 2008 11:10:02 PM(UTC)
Better to bribe a "small humanoid" as Seven of Nine would say.
She can "assimilate" me anytime!
#16 Posted : Thursday, May 22, 2008 4:42:54 PM(UTC)
bpboater wrote:
I used 1/16 inch acetal cut into 2.75 inch diameter disks under the rail stanchions. I sealed the acetal disks to the boat using lifecaulk silicone sealant. Then, i used Tefgel (available from Sailor's Solutions) to coat the stainless screws before installing them. I used the acetal because it is hard plastic that will not absorb any water, has zero conductance to avoid galvanic effects, and does not mush up into the bottom of the rail stanchion to block drainage. I used the Lifecaulk sealant because it is not an acetic acid cure silicone - acetic acid cure silicones create a long term corrosion problem on aluminum because they create a conductive and corrosive acetate salt over time. Lastly, I used the Tefgel based on advice from Broward Yachts and Pluckebaum Yachts. It really slows down the stainless screw -- aluminum corrosion setup.
Ordered the Delrin, Tef-Gel, and video cables for the engine room cameras today.
Drilled and tapped (5/16") 1/4" SS plates (4) for the aft cleats. Installed them by reaching through the bilge vent hole. Then drilled and tapped a single 10-24 SS screw (countersunk) to anchor them in place.
Powder coater called today to say the parts (aft handrail, hatch cover, stern lip trim - Radio Flyer Wagon Red) are done. This weekend I'll be laying down the second coat of Interlux Primekote epoxy primer.
I've been taking pictures for you'all.
#17 Posted : Thursday, July 17, 2008 3:02:48 PM(UTC)
Started a new thread: "HOW WE PAINTED THE DECK, COAMINGS, AND GUNNELS".
2 Pages<12
This page was generated in 0.114 seconds.
