Most of what you show there is pretty familiar. I guess you will have to sand or wire-brush to get down to either sound paint, or bare metal. Don't forget to etch the metal. FastJeff has a technique for deck fittings: He drills out the bad holes and installs rivnuts, then uses a machine screw to replace the fitting. This has worked well for me. I installed a folding ladder onto the swim platform, and chocks for the (heavy) dingy, using rivnuts and they worked fine. You can get them at
http://www.mcmaster.com/#rivet-nuts/=dzsbhg
The best thing about rivet nuts is that all the work is "on top", no one has to go underneath to hold a nut. I install them with a large rivet gun, but you can use a machine screw and a couple of nuts. I put sealer on them before putting them in, and then wipe off the excess. No leaks. If you get stainless flathead socket capscrews for the fittings, it looks awesome.
