NAV Light questions
Red5
#1 Posted : Friday, September 23, 2011 9:18:21 AM(UTC)
Red5
Both my red and green just cut out at the same time. I have a 75 37 sedan... When I pulled the lights to check the bulbs I found thre bulbs were good, so I need to track down a short. Got an avice on common places to look?
Also- My red lense is cracked/broken. Where can I buy a replacement lense?
#2 Posted : Friday, September 23, 2011 10:51:20 AM(UTC)
On why they went out at the same time I'd start @ the switches on mine at least on a 32'sedan there are 2 switches on the lower helm deck plus one up on the eye panel check that both are in the on position if so check 4 loose connections corrosion etc d'oh! do your lenses look like these Think if so I have 2 pair can't remember where I got them from will let them go $14 a pair + postage PM if interested
BigBigMs Live On Dancing
Docsnow attached the following image(s):
Docsnow attached the following image(s): DSCN3696.JPG
Docsnow attached the following image(s): DSCN3697.JPG
1 user thanked Docsnow for this useful post.
Red5 on 9/23/2011(UTC)
Red5
#3 Posted : Friday, September 23, 2011 11:20:35 AM(UTC)
Red5
I'll take them. Send me a paypal request to supervetteracer@aol.com if you want. My zip code is 40059.
Thanks,
#4 Posted : Friday, September 23, 2011 11:25:01 AM(UTC)
Does your white nav light on the back work? If not, check DC switches in the engine compartment if you have them...That got me one time d'oh! First place I went to, got lucky Pray Those switches get turned off when you monkey around in the bilge area Drool
Like Docs said, ck connections at switch, clean and volt meter to see it you are getting pwr at at and trough switch.
Good luck tracking that little grimmlin...Let us know what you find, even if it make you look like a dummy...we have all been there Eh?
jhemp3
#5 Posted : Friday, September 23, 2011 11:52:04 AM(UTC)
jhemp3
My navigation light problems have always been in the light fixtures themselves. Rusted or corroded connections.
Jim Hemphill
Detour
#6 Posted : Friday, September 23, 2011 12:58:27 PM(UTC)
Most likely the switch as mentioned earlier but keep an eye on the bulbs especially the "festoon" bulbs. The glue at each end dries out and the metal cap separates from the glass bulb. If you use the nav lights frequently the heat will dry everything much quicker.
Look very carefully on what remains of the red lens. You may see a "fig" number if it is made by Perko. Many of the lights Marinette used were Perko. I've found replacements on Ebay from time to time. I know the buy new lights and fixtures from Perko is ridiculously expensive.
My green lens cracked, I used super glue to put it back together.
You can pull the panel apart and test the switch for voltage with a multimeter.
Red5
#7 Posted : Friday, September 23, 2011 1:26:31 PM(UTC)
Red5
When I flip the switch the rear light comes on as does the front center light. Just now red/green. I have two little light up flashlights I use as spare nav lights. But I do need t fix this asap. Wouldn't that mean it isn't teh switch? Looks like I'm about to go on a search..
#8 Posted : Friday, September 23, 2011 5:00:10 PM(UTC)
You are correct...can't be the eye pnl switch or the bilge switch.
I'm not sure how the nav connections are wired into the switch. May have multiple connections to one switch for all lights...not sure on this.
Good luck Sick
Red5
#9 Posted : Thursday, February 09, 2012 3:37:01 PM(UTC)
Red5
Found my problem. The two forward Nav lights shae one wire. This wire had rubbed against stuff in my forward birthing area where the bilge pump is located. Fixed the wire and fixed the problem.
Jack Marchand
#10 Posted : Friday, February 10, 2012 10:45:00 AM(UTC)
Jack Marchand
Just a short comment, 'short' (pos. neg. wires directly touching with no 'load') wires will blow fuses/cb's, and 'opens' (due to corrosion, broken wires etc.,) just stop working. Sorry, just the electrician in me. Also, altho this wasn't your problem, our switches on these 'M's can be disasembled (carefully) and worked on internally, did it on one of my elect. opens. J. M.
This page was generated in 0.146 seconds.
