Originally Posted by: jralbert
After ascertaining there was some gunk in the fuel filter (and, who knows, some may have gotten past the filter), the engine was running smoky today. And there was a sheen on the water. Grayish/bluish smoke. Not black. Engine appears to run pretty smoothly past 1000 rpm...will stall below 800.
If I try to restart immed after letting it warm up, I have to push the throttle wide open before the engine will catch on. If it sits 15 mins (assume the carb bowl is clearing) it will start normally.
I am asuming the sheen could be unburned gasoline but it continued to appear on the water even after engine warmed. Clues/hints/tips?? thnx
Joel,
I see in a few post ago...you are trying to sell the ole girl
..engine dying while docking. Did you get new fuel?
Tell us about your carbs, old or new?
Did you run the engine under a load or just at the dock?
Couple of things come to mind, stuck choke, or maybe ignition problem to one or more cyl, which would cause no fuel burn in cyl. Inboard plugs are easy, outboard plugs...not so much
I would...
1) Make sure choke is working correctly. (3/8 cracked open when cold, full open when warm)
2) Trash stuck in needle seat/float..rap on side of carb with screwdriver handle several times.
3) Trash stuck in idle circuit...remove idle screws from carb (note number of turns), blowout with air, replace idle screws.
4) Swap carbs as pfhlaw suggested. 10 minute job
5) If old carbs, are you better off paying someone to rebuild?
Perhaps you would be better off buying factory reconditioned carbs (Edelbrock 1409s) Cheapest here
http://www.nationalcarburetors.com/marine/fourbarreledelbrock.aspx...You must weigh your options
Look at page 22 in this owners manual for carb troubleshooting
1409 owner manualLet us know what happens... good luck.
