Temp issue
Jack Marchand
#1 Posted : Tuesday, September 27, 2011 2:38:49 PM(UTC)
Jack Marchand
I had a small problem this year and I'd like some comments from our peanut galley, after burning up my raw water pump this spring on my starboard engine (long story), replaced and worked well. New issue is, my port engine gets up to 160 and stabilizes at load, the starboard will go up to 180 and falls back to 160 and does this repeatedly until after I run it hard, then stable at 160. Any thoughts? Jack
rv
#2 Posted : Tuesday, September 27, 2011 5:25:04 PM(UTC)
Sounds like a possible thermostat problem.
Bob
#3 Posted : Tuesday, September 27, 2011 8:54:02 PM(UTC)
I had similar issue with temp pulsing a while back. I believe I replaced the t-stat. That's the easiest part to get to but make sure to get the correct part. I think it depends on engine year. Take old stat out to match correctly. Also get a new gasket. The old one will be no good.
#4 Posted : Tuesday, September 27, 2011 10:52:01 PM(UTC)
Originally Posted by: GB49 Go to Quoted Post
the t-stat. That's the easiest part to get to but make sure to get the correct part. I think it depends on engine year. Take old stat out to match correctly. Also get a new gasket. The old one will be no good.-Karl
One of the major suppliers like Marine Parts Source or Hurrikain will tell you which tstat you need. Word of caution as you replace it..but you probably already know it -- if you have a heat exchgr, drain the AF from the HE first or when you pull the tstat AF will gush out..all over your nice clean bilge.
Also, consider ht epossibility of an air bubble in the cooling system - that will prevent the stat from doing its job properly. If you want to test the one you have, put it into a pan of hot waterand track the temp with something like a candy thermometer or one of the new, precise Infra red or IR temp measuring devices. Watch the stat open and close. As soon as you pull it out of the water (with tongs), the action should reverse.
They are cheap enough but a bad one causes too much anxiety
Jack Marchand
#5 Posted : Thursday, September 29, 2011 11:53:35 AM(UTC)
Jack Marchand
Thanks guys, I'll change out the T-stat this fall. boat is on the hard and ready for winterizing allready. Will post the results in '12. JAM
This page was generated in 0.084 seconds.
