Boat Mystery
#1 Posted : Monday, October 10, 2011 5:22:32 AM(UTC)
Apparently, my Big boat gets lonely (and nasty) when its companion (dink boat) has been taken away for the season. How do I know this? Because, for the second year in a row, Mr. Starboard engine suddenly had water in its rear cylinder(s) after running perfect all year long. And this happened twice last year after the dink was removed. Furthermore, it never happened in the previous 7 or 8 years.
This doesn't make any sense. The dink and motor weigh about 450 lbs and are offset to port, giving the boat a pronounced port list. Removing said weight causes the stern to be noticably higher and the boat more level. If water was getting smacked up the pipes (and I have new flappers this year) one would suspect it would be HARDER for this to happen now that the weight is off, however...
Anyone have an idea? I'm stumped.
#2 Posted : Monday, October 10, 2011 11:11:17 AM(UTC)
Originally Posted by: fastjeff Go to Quoted Post
for the second year in a row, Mr. Starboard engine suddenly had water in its rear cylinder(s) after running perfect all year long. And this happened twice last year after the dink was removed. Furthermore, it never happened in the previous 7 or 8 years. This doesn't make any sense. The dink and motor weigh about 450 lbs and are offset to port, giving the boat a pronounced port list. Removing said weight causes the stern to be noticably higher and the boat more level. If water was getting smacked up the pipes (and I have new flappers this year) one would suspect it would be HARDER for this to happen now that the weight is off.Anyone have an idea? I'm stumped.Jeff
Wow..this could really be serious. Here's one thought. Perhaps water gets in from, say,a passing wake. The boat is tilted more fwd, just enough so the water can't get out, held in part by the flappers. You would think that with flappers it wouldn't get in in the first place but perhaps these are not as good as the hand made ones you built years ago. Perhaps, they are sticking
Is there such a thing as a super size exhaust line check valve????
dependo
#3 Posted : Monday, October 10, 2011 1:53:26 PM(UTC)
dependo
Jeff, That sounds imnpossible for the water to lift that high. Could there be a small hole in the log manifold? How long do they last untill they rust out? Wayne
1973 express FB 32ft
twin 318
#4 Posted : Monday, October 10, 2011 4:54:54 PM(UTC)
Re-torque your manifold bolts.
Heat/cool cycles may have loosened them just enough to allow water to seep past gasket.
cap'n Brent
#5 Posted : Tuesday, October 11, 2011 2:08:51 AM(UTC)
cap'n Brent
Pfhlaw it's to my understanding that water should never get close to ex port . I have threaded ports under the ports that I think are for pyrometers. When engine is off open them hang a can under the hole back into waves n see if you have water come in. My risers don't have the up trap. At the end of my logs it keeps a straight down line gravity pulls the water out of mine then exhaust blows it out the back. Mine is a 73 and I don't know if its like that stock I'm the 3rd owner. Also if you pull your logs off and cap off the aft end,run a hose in the front hose hold it as it is on the engine if water gets into exhaust port its time for a new one mine is a 73 and I have 4 new logs on mine
#6 Posted : Wednesday, October 12, 2011 7:40:42 AM(UTC)
Boat lists to port with dink.. You did not mention which side of the engine cyl are on that have water in.. one or both rear cyl?
Now if there was prob with the port manifold on your STBD motor.. water would tend to sit on the on the inboard side of the log of manifold while the dink is there. Once removed boat would levels off or may even rest slightly to STB. Water in manifold moves toward the block and leaks into the cyl due to crack or gasket failure? Just a thought
#7 Posted : Thursday, October 13, 2011 4:40:05 AM(UTC)
Thanks for the responses.
Going to the boat today after it's sat for a week. Will see if the water is back and let y'all know.
#8 Posted : Saturday, October 15, 2011 6:24:51 AM(UTC)
No water in starboard # 7 this time. Not sue why it was there LAST time, but I'm pulling the elbow and riser to take a look anyhow.
Hada bit of an adventure going from my slip to the haul out well to have her pulled for the winter. Just as we approached the well a t-storm--that had been threatening for some time--blew up BIG time! (From blue skies to liquid, roaring, raining hell in ten minutes flat.) I worked the throttles (twin screws) the best I could to avoid hitting pilings, the dock, a party barge, the well timbers, etc. It was all for naught, for the wind--now at 30 mph or more--were in control of my boat and there wasn't a damn thing I could do about it.
The marina guys, now soaked to their skin, secured a line from the bow to lift wellwell, while I got a stern line around a nearby piling. The boat was now secure--though it sidewaysways from lift wellwell. And then we all waited, the drenched marina guys taking a fearsome beating, the motors idling (nicely, thank you), and the wife and I wondering how much damage had been done. (None, mercifully.) . Ten minutes later the storm had passed, the blue sky was back, and we had the boat in the lift well.
What a way to end the season!
#10 Posted : Saturday, October 15, 2011 6:54:51 AM(UTC)
AHH yes another BigM taking a licking d'oh! & kept on ticking Dancing Dancing Dancing Just another reason 2 own a BigM Applause
#9 Posted : Sunday, October 16, 2011 12:26:58 AM(UTC)
What a way to end the season!Jeff
Awful! Sorry to hear it - but dull days are just that. At least you got a story to tell and it will get even scarier every time you tell it with a little more embellishment (as lightning struck the travel lift...as a waterspout formed just off the bow...as ...) We should have a contest for the next good line.
By contrast, I just ended the season with a finalized sale! Now I have some free time in the spring, Jeff to head north and watch with Millie as you prep the bottom.
#11 Posted : Sunday, October 16, 2011 5:15:40 AM(UTC)
Lightning! I forgot to add that lightning was....you know.
Joel: If you ever head to Allentown again, let me know and I'll meet you for coffee.
PS: Congrats on selling your boat.
#12 Posted : Monday, October 17, 2011 4:14:41 PM(UTC)
OK, there's your answer.
With the dink in place Doc can't get that garden hose up your exhaust.
I read somewhere about some superior flappers that are much more effective.
Sorry I can't be of more help. It seems that when the engine stops with that exhaust valve open and left at the dock... Could some sort of vermin, other than Doc, be crawling up there when the port is underwater?
This page was generated in 0.999 seconds.
