Ok let me try and dispel a myth regarding 12 volt negative grounding on our boats.
Here is a simple test....
1. Take a test light or voltmeter and touch it to the positive post of one of your batteries and the negative to a stringer..
MAGIC.. you will read the voltage from the battery.
2. Trace the main ground wire from the battery(s) and you will find it terminates with a bolt on a brace on the bulkhead which is welded to the stringer thus to the frame!
3. Continuity check from Alternator to hull yes... it will have continuity!
The difference is no DC voltage is allowed to flow directly to the hull if you have a galvanic isolator properly installedon your AC green ground. The AC current flows through your neutral and not the ground. Now if you were to jump from the black postive to the ground it would show voltage sine you provided the route for it to flow through.
NEVER DISCONNECT THE GREEN GROUND WIRE FROM YOUR SHORE POWER. Very dangerous!
So where is the confusion? electronics etc should route to your ground bar on you electrical pannel..why you ask.. it is suppose to be a clean connection to ground. (Brass bar etc.) Corrosion on the DC negative grounds or positive increases resistance thus load..heat.. and can even cause a fire. (toaster syndrome)
Now with our aluminum boats.. we need to maintain isolation from dissimular metals.
Two disimular metals in a medium (salt water is the best or contaminated fresh) creates a battery. One becomes a cathode the other the anode. In the case of our boats the alluminum becomes the anode and sacrifices to save the bronze, steel etc.
This isolation interrupts the continuity from the hull, engine etc. thus there is should be no bonding on our shafts and any dissimular metals on our boats. Thru hulls, props shafts etc.
We add anodes to compensate for any continuity between metals. Even if you had a bonded shaft you could add enough andoes to protect it but it is difficult so isolation is much simpler and cheaper.
DC leakage is a major contributor to galvanic corrosion. (or electrolysis) One culprit is often bilge pump splices that are in bilge water and not water tight. small currents can flow through the water between the splices and corrosion can begin.
DC leakage is what we wish to avoid.
Confusing I know but check your boat out and it will be wired pretty much as described.
Have a great fall and winter,
