Read a post by FastJeff awhile ago about fogging engine without ignition (pulling coil wire and grounding it) Crank engine over while spraying fogger.
The argument was that the oil was being burned off if there's ignition in the cylinders.
What do you guys think? Everything I read says to spray while running out last of fuel.
Help us out Jeff, make sense to me..
