Howdy Guys! Long story short, our boat, was moved, with my permission, for a Jimmy Buffet party. I was working 70-90 hours a week, so I couldn't do it my self. Two members moved the boat under it own power, but they left the ignitions on! Two weeks later, I get to move it back. Open engine compartment to check engine oils (twin 318's) run blower, go to turn keys on, down below, by the dinett, and both keys are ON! Moved the boat to it's spot with the work boat in the rain (pouring down) I got pissed & wet. Fast forward to time to winterize two 318 & 6.5 genny. No nothing anywhere! I just start replacing parts (spares I have on board) Engine #1, the starting resister (four prong) had fallen apart, no problem got a spare, replace coil, got a spare, replace 5 prong electic box, got a spare. Prime carb, fires right up! Three gallons anti with the thermostat out, and choke engine with fog! Done! Have a beer!
Engine # two, Only have five volts @ plus side of coil. Check and clean fuse on keyed ignition switch below. Have gauges jump when i hit first spot on ignition switch @ lower console, now five volts @ plus side of coil!
Question? could i just jump twelve volts from battery to plus side of coil?
I have new 5 prong electic box ordered to p/u monday...it was 26 degrees last nite, and can't leave anything plugged in @ our marina.
I have electonic ignition, no points. I'm hopeing I didn't blow out the reluckor (spell) on the distribitor. The resean I ask is I can usually feel something rocking the distribitor.
So.....any ideas on the 5 volts to the plus side of the coil???? Bad switch @ the key??
Bad ignition switch @ the console??? Bad power cutoff switch down below??? Bad wire??
Any ideas??? Sorry so long winded. Merry Christmas!
