Hello from Florida! I've been working on this 34' Marinette Rivercruiser houseboat now for years. It's like 20 separate little projects, but overall it's a huge undertaking, see my photo-sharing site:
http://s1216.photobucket...dd377/projecthouseboat/ But first:
My most recent little project is an idea on how to draw water up from the thru-hull into the boat to be used by a washdown pump or in the galley where I can use lake water (if needed for rinsing etc.) pulling it up with a manual diaphragm pump. With my boat all the water intake strainers have been welded over and I do not want to make any holes in the lower hull itself. I have 2 thru-hulls I can use: one for sink and shower drainage, and then this other one which I plan on using for drawing water up from lake if needed. The thru-hull holes appear to be at the water line (possibly above it a bit.) I purchased one of the 90 deg Maeleron hard line thru-hull fittings from Hamilton Marine already and it's installed (see pic 1.) I was looking around for fittings trying to see how I could do this and have come up with using a 90 degree Maeleron with the threaded Attwood one shown in the picture(#2.) That Attwood fitting which has the threaded ends is the only one I've been able to find. I wish I could find one like that but made of Maeleron. By using those two together I can have a hard-line going out and down (like a siphon) as well as a hard-line going inside and up(to the galley/washdown pump etc.) but I still wonder if this will fly (a surveyor would probably shake his head.) Actually the idea seems a little Kludged/Jerry rigged but I can't think of how else to do it and NOT drill any holes through the bottom of the hull. I wish I could find a thru-hull that's threaded on the INSIDE so I can screw in a 90 degree down turn to siphon up water when needed, and then remove/unscrew it when not used, but I haven't found one. Do you know of anything like that Attwood fitting (preferably made of Maeleron?) Opinions and criticisms welcomed.
First pic of black 90 deg. is one I got from Hamilton Marine. Second pic. is close up of threaded Attwood fitting. Third pic. is of overview/sketch of water draw up idea and 4th pic is close up of thru-hull area.
http://s1216.photobucket...oat/Thru%20hull%20idea/
Thanks for any help on this, Roger from Mt. Dora, FL
