Marinette Aluminum Boat Forum
General Category
General
Improved idea on how to draw water up from lake.
Thanks for the responses on my idea on how to draw water up (for wash-down) from lake. I've fine-tuned the idea a little. Since the boat is fairly large I will need good pressure to get all the way to the top and front of the boat. On shore/dock I will have hose water access. While out on water I will use my boat generator to power the ShurFlo Industrial A/C powered 30PSI pump(with 9ft vertical max draw)for a good solid water stream for wash-down/rinsing(and wetting down the ladies in the bikinis when needed.) The wetting down the ladies part I know for sure I will do but what do you think about the rest? Is it correct to locate the pump as close to A/C power as possible? I was thinking about having the pump in the engine room (note: I have converted this to an outboard and do not have an inboard.) Check out sketches on: http://s1216.photobucket...oat/Thru%20hull%20idea/ And the whole boat project on: http://s1216.photobucket...dd377/projecthouseboat/ Also see anode section of that projecthouseboat pics. Thanks again Marinette owners.
Groups: Admin2, Member2, Admin Joined: 11/30/2011(UTC) Posts: 7 Points: 21
Thanks: 1 times Was thanked: 3 time(s) in 2 post(s)
Please use the new userids.
General Category
General
