My issues with polyurethane foam (Spray foam) come mostly from the following
document:
STANDARDS FOR THE CONSTRUCTION
AND INSPECTION
OF SMALL PASSENGER VESSELS
http://www.tc.gc.ca/publ...717/pdf/hr/tp11717e.pdf
19.1.3 Restriction of Combustible Materials
(a) All insulation including pipe and duct lagging shall be of approved
non-combustible materials.
(b) The use of polyurethane foam as insulation material is not
permitted.
They are quite explicit about spray foam for whatever reason. It has
also been claimed that it will promote corrision on Aluminum Hulls.
In houses extruded polystyrene sheets and similar products
must be covered by at least 1/2 inch of drywall. In a house you can
just run out the door, and let the fire keep you warm!
About "Reflective Bubble Foil Insulations & Radiant Barriers"
While they are better than bare aluminum, they seem to get poor
reviews in much of the literature. Still it may be the best soluton.
http://www.healthyheatin.../Page_55_o_bldg_sys.htm
From your posts it is clear that just stuffing rockwool in,
will not work :(
