I have not replaced my rear deck yet, but it is the next major project on the list.
I am looking for any comments on the following ideas for a replacement rear deck on my 32' Sedan.
1) Replace the deck with 1/2 plywood cover with 1/8" or thicker PlasDeck. The pluses are it look very durable not too bad to install. The problem is it is expensive over $1200 for PlasDeck materials plus the wood ect.
http://www.plasdeck.us/index2.htm
2) Replace with bolt down aluminum plates??? Height problems to match with door sill, more noise transmission, cost.
3) Replace deck with 5/8 plywood and seal and paint with Durablak (self applied bedliner/ no skid coating). The down side will it look good??
http://www.nonslipcoating.com/
4) Do an original replacement with Nautolex
http://www.omnova.com/pr...tery/marinedecking.aspx
I also looked a King StarBoard plastic, I called the MFG and they talked me out of it because of the thermal expansion 1/32 per square foot 40 degree temp change. You would have trouble sealing, and holding down (the screw holes would have to be ova led or larger to let the product move. It is more for non constrained areas like a swim platform ect.
http://www.kingstarboard...s/_StarboardFamily.aspx
Any ideas, suggestions or experiences?
How long does a Nautolex deck last on average?
Robert
