If you want to replace the original thermal breakers with the same thing, you can get them at
http://www.alliedelec.co...mp;sid=480A87802B56E17F for $21.
Personally, I don't like the thermal breakers, and in fact I have given away the ones I remove.
The Snapak breakers are pretty good, their slow curve approximates what you would get with a purely thermal breaker and is excellent for protecting the wire from overload without nuisance tripping.
Marinette used all 20A slow breakers to protect the wiring from shorts. Note that most electronics has its own fuze, which should provide proper protection. For a known load such as the reefer, you can always use a lower value breaker or faster breaker for protection, but this complicates things. If you have a water pump that draws 7A, you could use a 10A breaker. The no-delay breakers are usually used in special applications. The fast breakers are hard to find in stock.
The only thing that I don't like about the snapak toggles is the plastic handle. The metal toggles in the AP-MIL series I use look "period" for an older boat.
Don't worry about all those options, nobody stocks them all anyway. What you want is paddle handle, black, 20A, single pole series, slow, AC/DC (so you can use them anywhere) nickel knurled nut, vertical (toggle goes up and down instead of sideways).
You can get these (T11-2-20.0A-01-11AL-V) at Newark.com Stock No. 90C0671 for $15.60.
I looked at
www.pocosales.com but they do not post prices. Sounds like they might be a better deal than the usual industrial sources like Newark. They have a really nice parts selector.
Note: 2-pole breakers are preferred for AC, but Marinette didn't wire it that way....
