Well, I am less pleased with the personal Code Sourcery Stack ($199) for Stellaris. Code Sourcery has been very good on responsiveness for a product that does not get support. They upgraded the package free of charge to the ARM EABI. I do like the professional support (as many calls as needed in a year). CS uses the GNU toolchain and Eclipse. The ARM EABI is an upgrade of the product for Stellaris to do local emulation, which I really like. Still it's a low cost stack. The Free version (lite) is OK, and used by a large number of people. The Keil Stack works very well, and is incredibly easy to use. It seems to be very well supported, but it's very expensive comapred to GNU tool chains (It's their info, so you can get an Idea of the cost from Digikey for ARM3-cortex. Keil supports GNU, but provides their own tool chain also with Realview.
As for the LM chips, they appear to be an excellent platform. At a couple of bucks apiece they do a lot.
A real manufacturer would probably choose the Keil Suite. They would also likely use the KVASER stack.
-------------------------------------- On windows CE and per device charges -------------------
Some OS manufacturers charge a per installation cost. This is OK for the hobbyist, but it really bites small manufacturers. Windows CE/embedded has this challenge. Large Manufacturers have negotiation leverage.
An excellent article is and
http://www.nxtbook.com/n.../index.php?startpage=32
I may buy myself the Keil version as I like their product, but it's not for the average hobbyist in cost for good size products.
