Well, the sand blasting was completed on Saturday and the first coat of Interprotect was (feverishly, but thoroughly
) applied. It was rolled on and it took a bit longer to apply because of the pitting that I knew was there (had been painted over by someone in the past [and some pits are pretty deep]). Next process will to be to apply PC-11 marine epoxy to fill in the pitting. This, I believe
will make the application of the subsequent coats a lot easier and go faster.
The one thing that had me initially perplexed was that the Interprotect 2000 shows a 3 to 1 ratio of paint to activator. Having not used the product before and the paint showing as a "1 gallon" I wondered... "Well, if there are 4 quarts to a gallon and there's a 1 qt activator with the kit, that means I'll have a quart left over?!? [3 qts paint to 1 qt activator]". Opening the paint can answered that question: The VOLUME of the can is 1 gallon, but the AMOUNT of paint is 3 qts. This would allow the purchaser to mix (carefully) the full quart activator in to the semi-full 1 gallon paint can.
NOTE - You will want to use a 5 qt pail for the 1st coat mixing. This is to allow for 19.2 oz of thinning agent to be added to a full gallon of paint (15%).
Disclaimer....
The following section is made without benefit of any libation or brewski. Comments made should be taken with the application of a minute amount of sodium chloride....
Joel...
I'm not sure how much speed I'll pick up. With gas prices as they are, or may go up to... I'm thinking of using a new type of bottom paint: ... HeliumH2 ... It's intent/use is to lighten the boat which will help it move through the water with minimal effort.
Bill Cassedy
Sunset Seeker
32' SB
318 Cu In Chryslers
1.5 Velvet Drive trannies
