yooper wrote: A lot of Marinette owners feel that the railing should be removed and all the screw holes filled with rivnuts and nylon washers. If I end up spraying sand on the dang deck anyway, why be so careful?
Yoop: One possible reason to remove rails is to get at source of corrosion that seems to creep out into widening areas. So if you get at the source area and prepare it properly, you will probably be able to delayl the reappearance of the problem.
Jeff's idea of putting washers under/over the screw holes is an excellent and easy way to keep water draining away. Good luck. Since it's a project boat and time not of great essence, you can relax and do one thing at a time. Ok, maybe two.
